MC Settings?
alanh
Central Texas
I’m a new Mavic Pro owner. I want a definitive explanation of the vehicle control system settings. In particular, I’d like a description of the effect of each of the following settings.
MC Settings – Advanced
EXP
Throttle Up/Down
Rotate Right/Left
Forward/Right – Backward/Left​
Basic gain
Pitch (80%-120%)
Roll (80%-120%)
Yaw (80%-120%)
Vertical (80%-120%)​
Sensitivity
Altitude (20%-100%)
Brake (10%-200%)
Yaw Endpoint (50%-250%)​
Cinematic Mode
Mode Gain (10-150)
Yaw Sensitivity (50-250)​
I have read the DJI Mavic Pro User Manual (2.0) The manual only says (about the Flight Mode icon and underlying settings): “Tap to configure the MC (Main Controller) Settings. These settings allow you to modify flight limits and set gain values.” I have read all the relevant forum threads I could find. I have watched all the YouTube videos I could find on the subject. I’m still searching.
So my question is simple. Does anyone have manufacturer specifications on the effect of each setting? Or can you refer me to a good source.?
Thanks for your help!
You Tube is your friend .:)
And if that don't cover what you look for just look some more as there are many videos there .
Reactions: VortexSpin
yankigsm
