Memory Slot Issue
bmwbob
California
I just sent in my MA2 for repair because the memory slot stopped releasing memory card. I'm able to insert, but won't release.
Did you try pressing a paperclip against the SD card to see if it would pop in-n-out ?
Reactions: Scubadiver1944
Mine's always been difficult to install/remove with my fingers. I've always used the flat corner of the adapter to get it to push in far enough to latch/release. My other drone is easy to get the card in and out with just my fingers.
I use a small pair of tweezers to both put the card in (push it in until it locks) and pull it out (push it until it unlocks then pull it out).
It used to lock and release with a slight push, but not anymore :( Off to DJI for repair!
MeDroningOn
