Mini 2 attitude indicator disappeared on last flight. Was fine before.
Hello from the Hoosier Heartland rcb.
Yep, big surprise since the update.
Click below for the search results and get up to speed.
Some like it, some don't.
It's a learning curve that we all have to adjust to.
Welcome to the Forum. :cool:
If you are flying on an Android device, you could try it and if not satisficed, I think you have the option to roll back to a previous version through the app.
But you might lose anything else that has been upgraded through the app.
I don't think Apple users have that option. ?
I have the updated app but haven't flown yet due to the weather.
Attitude indicator just disappeared from bottom center of screen. Previously fine. Recalibrated ICU but no change. Concern? Que passa?
That was never an attitude indicator, but rather an orientation indicator.
The new one is an attitude indicator as it shows the tilt angle of the AC, as well as orientation of you with respect to the AC.
Thanks for correction and update.
I am using an Apple phone due to past problems trying Android on dji drones. I maybe accidentally installed the new app. I see there is a new firmware available too and wonder if I should be afraid of that too. Anybody know?
How and where should the new attitude indicator appear on the screen?
If the mini 2 uses the same app as the MA2, tap the map in the lower left of the screen and it should pop up.
Tap it again and you should get a mini map.
The mini map has four corners, each of which will do something different to the map and it's function when you tap it.
I like using the map but the attitude indicator does have it's use.
Not sure what you mean by that but if you will stay up in
the App section you can see when apps update what members
say about one before you do one.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Thanks, great site!
It’s already been a great experience.
denmaytre
