Mini 2 ND Filters
nathankw
London, UK
Does anyone know if filters designed for the Mini 1 will also fit on the Mini 2?
And has anyone tried using them on the MM2? Does it improve quality in bright daylight?
I much prefer the look of a 180 degree shutter so tempted to get some filters.
Reactions: CLAYB.7
Thanks for clarifying.
Next question - is it better to get straight NDs or the polarising version?
I guess the ideal would be to have both but if I just want to get one set which is the better option.
I know PL filters can give darker skies and reduced glare, but of course we're not able to rotate them in use so I wonder if the end up (sometimes) doing more harm than good?
Straight ND filters. Polarization will net different results based off your position, the sun, and the target.
Reactions: CLAYB.7
I just got my UV filter yesterday and it works absolutely great I was worried to but took the chance that it would work out ok with it fitting my MINI 2 and it fits great I got it from AMAZON for $15.00 (PGYTECH)-UV FILTER-(PROFESSIONAL) I hope it all works out for you. God Bless! Sincerely Clay B.
Reactions: MilosB
That's great! ?
Reactions: CLAYB.7
"UV / Protective Filters. Let's get UV filters out of the way – indeed, unless you are using a film camera, they are completely useless for the task of blocking UV. That's already done by your sensor filter stack, which contains a UV blocking filter."
Reactions: CLAYB.7
Hey Brother I appreciate the link man I wish I would have known that before I went and spent $15.00 on something I already had LOL HA HA HA HA HA HA oh well you live and you learn but that is a Great link Thanks again and God Bless! Sincerely Clay B.
No worries! Just be glad you didn't spend more or buy extras!
Another filter that's almost pointless on a drone would be a CPL, as you have to physically rotate it to get it to work. ND filters on the other hand can be very handy to reduce your shutter speed on a bright day and get some motion blur to your video.
Reactions: CLAYB.7
One thing UV Filters can do given they don't degrade the images, it protect the camera lens itself from damage, even on my SLR I keep a UV Lens on just to protect it from scratching, I'd rather have something hit the filter & scratch that then hit the camera and scratch the lens.
Reactions: CLAYB.7
Me too. As you say it's much cheaper to replace a scratched UV filter than having an expensive lens ruined.
Reactions: CLAYB.7
keyz
