So I installed the Master Airscrew Stealth propellers on my mini 2 and nearly every flight it says there is a payload detected and then limits my top speed and flying distance. Has anyone else experienced this problem?
I have switched back and forth a couple times now and it only happens with the MAS propellers so they seem to be the problem. Still not sure whyI seem to remember seeing this in the past.
Try the stock props and see if the message goes away. If the message disappears, so should the MAS stuff.
I think each motor has its own ESC but I could be wrong.the ESC's control each ,pair of corresponding motors ( CCW or CW )
Yes I have the same after I installed 4 pair of New orginal DJI MINI 2.SE propellersSo I installed the Master Airscrew Stealth propellers on my mini 2 and nearly every flight it says there is a payload detected and then limits my top speed and flying distance. Has anyone else experienced this problem?
At a guess the detection system monitors the necessary rpm for a flight action and, if the rpm are higher than should be required by x%, issues the warning.. If correct reduced rpm would counter that.The Triple Props added more weight than the MAS Props did, and, they slowed the Motors' RPMs, as well,......
