You are correct PhiliusFoggg. I kept a MM car charger for use with my new Mini 2 but it slightly undercharges the Mini 2 batterie (as you say 8.4v vs 8.7v) so I only use it in emergencies eg. if I need to charge a battery on route to a flying site etc.That is due to differences in the shape of the battery.
However you CAN use MM batteries in the Mini 2 so the relative dimensions relating to the connector must be the same and the pin outs must be the same.
The concern might be voltages and whether the little cuboid thing contains any voltage limiters. From memory MM batteries are 8.4V whereas Mini 2 are 8.7V thus the thing might not fully charge Mini 2 batteries.
Yes... BUT....Will this mavic mini powerbank charger work with new mini 2 batteries? Someone tried it?
Good catch! I haven't tried this updated one nor needed it, but I'm sure they just modified the internals of the older one for the Mini 2's LiPo batteries. I have two of the previous version for my Mini 1 because I didn't buy the fly more kit so didn't have their charger. They will partially charge the Mini 2 batteries, but as it says, you can't use the updated one with the Mini 1 batteries. The advantage of these over the DJI charging bank that comes with the fly more kit is that the batteries charge simultaneously if you have enough charging blocks or ports to accommodate them. The new ones are also QC 3.0.I did some research and found battery chargers for mini 2 https://www.amazon.com/gp/product/B08RRVW12S/ref=ox_sc_act_title_1?smid=A210697I83MUJR&psc=1
Someone tried it?
If you have a look in post #20 of Has anyone seen a simultaneous multi battery charger for the Mavic Mini? I wouldn't mind betting the arrowed pot is a voltage setter and that there is something similar in the "thing"...., but I'm sure they just modified the internals of the older one for the Mini 2's LiPo batteries. I have two of the ......
I got anker powerbank with 3 output usb slots so it would be great to charge 3 batteries simultaneously through powerbank.Good catch! I haven't tried this updated one nor needed it, but I'm sure they just modified the internals of the older one for the Mini 2's LiPo batteries. I have two of the previous version for my Mini 1 because I didn't buy the fly more kit so didn't have their charger. They will partially charge the Mini 2 batteries, but as it says, you can't use the updated one with the Mini 1 batteries. The advantage of these over the DJI charging bank that comes with the fly more kit is that the batteries charge simultaneously if you have enough charging blocks or ports to accommodate them. The new ones are also QC 3.0.
While the charging hub that comes with the Mini 2 fly more kit is convenient, if charging speed is ever an issue one could get one of these adapters and a wall block, put one in the hub, one in the drone and charge one with the adapter, assuming you had enough charging blocks. You'd get all three charged in 80 minutes rather than 4 hours.
I saw this one. It is nice cuz it can be used as powerbank cuz it have output and input. On the other hand it is bigger then this US $10.79 10% OFF|YX dla DJI Mavic Mini 2 QC3.0 szybka ładowarka USB ładowanie z typem C ładowarka kablowa dla Mavic Mini 2 akcesoria do dronów|Ładowarki akumulatorów do dronów| - AliExpressI have a YX Mini 2 charger on route from Alixpress, I had the Mini 1 version with issue. Will update when it arrives
13.99US $ |for DJI Mavic Mini SE QC3.0 Fast Charger Battery USB Charging With TYPE C Cable LED charger For Mavic Mini 2 Drone Accessories|Drone Battery Chargers| - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
