Mini 2 prop holder in fmc set
Tobbias
Hereford , U.K.
Hi all ,
A friend has just bought the mini 2 fmc combo set up which comes with a prop holder for storeage , he has said about the top strap holding the props close to body.
We understand that the mini 1 had a problem with the props being thin that they can distort if not stored correctly , has anyone had a problem with the mini 2 doing the same or with the thicker props is this not a problem , or is it too early to tell with the newness of the drone.
Thanks for any advice or info on this subject.
i use the original DJI prop holder that is basically the same design to keep the props secure, and have not had any bending issues with them the only problem i had was i had to cut the foam in my hard case to allow the holder fit in the space provided when it is attached to the drone
Badeff
