Mini 3 Pro No Red Led Low Battery indicator
harleymhs
Hey Guys, Got my Mini 3 Pro this week.. I noticed last night when my battery level went low then went critical low , the drone did NOT Flash the LEDS Red.. As per the manual it will flash red when the battery level is low. It started to return home cause it had low battery and was still flashing Green. Anyone else see this? TIA
@harleymhs hi fellow flyer ,if you go into the manual and find the section on the Led light meanings ,then you will see it says that the lights colours refer to the drone without the motors running ,so before trying to take off ,they dont change during flight
coregambit
