Hi, newbie here soon taking delivery of a Mini 3 Pro with DJI RC remote. Does it need two SD cards? One for drone and one for the remote?
get 2 128 gig SANDISK ultra fast sd cards ,you will use these over and over again ,thru trial and error ,i discovered if I spend hundreds on a flying camera it is worth the few extra dollars on the best cards possible
A card in the controller can be handy when you use offline maps, since they'll be stored on the card if it's available.
No, you need to manually select and download them. It's a PITA because each map is tiny. If you want to cover any bigger area, you might need to download a dozen or more.Thanks, do the maps save there automatically just by viewing them on the RC?
Yeah, **** straight.get 2 128 gig SANDISK ultra fast sd cards ,you will use these over and over again ,thru trial and error ,i discovered if I spend hundreds on a flying camera it is worth the few extra dollars on the best cards possible
UHS II only if you have the right gear for your computer. If you have an older adapter or don't have USB gen 3, you won't see much speed boost. At the same time, the cost increase may not be that much (these things vary weekly, it seems) and you'll be future-proofed.Yeah, **** straight.
In fact, I would recommend spending a bit and getting UHS-II cards so you don't have to wait forever to copy data off the card. What's your leisure time worth?
Hi, I like to make screen recordings as well as drone recordings, as the screen record shows height, speed etc. If you want to screen record on the DRI RC, you do need the sd card .. it only records fairly low res so I am using a v10 card, and works perfectly. If you don't want a screen record saved, then you don't really need the sc card in the c ontroller.Hi, newbie here soon taking delivery of a Mini 3 Pro with DJI RC remote. Does it need two SD cards? One for drone and one for the remote?
