Mini 4 Pro Waypoint Flight Test Video
IlluminationsfromtheAttic
My first attempt at creating a video with the Mini 4 Pro using repeated waypoint flights, showing the transition from a bright summer day with a clear sky to a stormy day in early autumn. I did find that with this flight the Mini 4 Pro seemed to have a hard time replicating more complicated movements precisely each time, the shots that worked best involved simpler movements.
Reactions: Torque
I think waypoints works best when not too close to terrain / objects. If you are further away the inaccuracies of the GPS location from multiple flights of the waypoints is well masked... if you are close its obvious the drone isn't exactly in the same position each time.
sscott062
