Mini Camera Mounts
EdKrimmer
Fontana, CA
Mavic Mini - working fine, any issues are the pilots fault. Thus the camera has become partially disengaged. Specifically the 2 rubber mounts in thus photo. I can’t figure how they should be re-attached.
Just hop on over to Youtube for an assembly video of your model. If anything is snapped you will need to replace it.
Yeah, could be worse, but basically that top cover's gotta come off.
Reactions: Cafguy
I’ve been looking on YouTube- haven’t found something this specific yet. Don’t think anything is broken though. Just came off (wouldn’t know how???)
Reactions: Cafguy
The video above you shows the correct way.
Reactions: Cafguy
Both damper rubbers have been rotated by 180 deg, they should point inwards not outwards.
I don't know why this happens but it has been seen before.
Once correctly orientated their inner ends go through the holes in the shell.
Be careful not to tear the dampers when rotating them and inserting them.
If you inititally poke the rubbers through the holes use some thing with a rounded end, so as to NOT puncture the rubber. Once the lip is partially through it is probably easier to pull the remainder of the lip through, again with a rounded end tool of some sort, perhaps bent nosed tweezers.
Reactions: Capt KO and Cafguy
BausInGV
