Minicity
lordmach
Reactions: calmar81
Really like the effect... think it’s called „tilt-shift“, where fore- and background are blurry? Did you shoot in higher framerate to speed up the movements to increase the miniature effect?
Think it could be a bit more blurred on top / bottom and sharpened in the middle to emphasize the effect. And getting a bit closer (you have the M2Z, right?) could help even more.
Edit: Found the spot from the German Telekom that brought the effect to a broader audience some years ago:
Reactions: lordmach
I used Mavic Air. Tilt-shift indeed. Stabilized first then blurred top and down. Zoom made by manually changing scale, blur and vignette. 30fps record and made 8x speed up and colors little bit up. [emoji106]
Reactions: calmar81
Thanks for the details! Very good work, thanks for sharing!! :-)
Reactions: lordmach
djieastcoaster
