Motor current error and control loss?
James474474
I have received the 'motor current error numerous times without issue and as per who guidance believed it to be a messaging error. However, last week I got this message and the MA then seemed desperate to crash itself into the nearest trees. Luckily the control loss was temporary and I was high enough to suffer no ill effects.
Flight log:
The control loss was after the warning at 2:36.
Can anyone see anything obviously wrong?
Might need to pull the more detailed log from the tablet/phone: How to retrieve a V3.DAT from the tablet
This has a lot more info, things like granular expected/measured motor RPM, voltages, per motor current etc...
To upload it here you'll probably have to rename it to <something>.txt. Hopefully one of the log gurus like @sar104 can find time to take a look.
If you've had the error come up before, and now it's starting to fling itself off course there's almost certainly an actual problem there though...
David H
