Hi folks.
I'm getting the above error every time I fly my Mavic Pro which I purchased last week (used but appeared immaculate).
Wondering if anyone would mind checking my flight data to see if they can work out which motor is causing the error, assuming it is a motor and not something else.
Template filled in below....
Problem?
Getting "motor current error. Check your propellers and fly with caution" on every flight, as soon as I take off.
Was unit in a crash?
Not that I know of(purchased used last week but looks new and had around 2hrs previous fly time)
What have you tried so far?
Change all 4 probs to new. Both sets original DJI.
Inspected and cleaned motors with camera air blower
Checked motors for damage and constant rotation. All perfect.
Factory reset drone
Rolled back to previous firmware then back to current.
Calibrated IMU and compass numerous times.
Calibrated sensors
What device are you using ( iphone , ipad, Samsung , etc)?
Galaxy S10
What firmware are you running ( aircraft, remote controller)?
01.04.0500
What Go app version are you using?
4.3.32
Any modification? (if so what)
N/A
Did you change anything or install any apps? (if so what)
No
Do you have a video or pictures of the problem? (if so post link)
Have a screen record but it only shows the error showing within a few seconds.
It happens in normal and sport mode, even if I take off as gently as I can. Temperature is around 7c. Wind or no wind doesn't seem to make a difference either.
Many thanks in advance ??
Problem?
Factory reset drone
Calibrated sensors
Galaxy S10
01.04.0500
4.3.32
N/A
No
