Motorola Edge (6.5" wide) with Mavic 2 Pro controller
KevinD
It's tall but not quite as tall as iPhone 12 max or Samsung S20 ultra.
It can fit but does not fit well. Best to remove any phone case.
The Edge ships with a free case and the opening for the USB port isn't large enough for the standard cable from Mavic 2 Pro controller.
A few options: use a different case, remove the phone from the case, cut the case to make the hole bigger, use a different cable.
Flying today, I used my old phone because it fits better. But because the SIM card is removed and I have no cell-data, I can only guess that the map (included in Go4 app) will not display; I did not verify that today.
If you want to keep the case on, the tablet holders for the Mavic remotes make it easier to work with larger phones in case. And get a longer USB cable. It just makes it so much easier to work with. I posted some pictures of the Pgytech Pad holder with my Note 20 Ultra in another post.
RTLflyer
