Motors do not Start Can’t upgrade or downgrade firmware Mavic 2 Pro
jftman
western NY
No ability to use both Dji Ass2 or Go4 to finish any upgrade or down grade on the M2P.
In ass2 it gets to 20% on the button, restarts the drone two times before the update fails. With go4 it gets to 44% restarts drone two times and fails.
Says try again, contact Dji with logs.
I diwnloaded any logs to my PC if it may help.
Upon finding the drone will not spin motors, smart controller said everything up to date. I first trued ass2, and figured if no joy to refresh, twice, I would down grade, it fails too.
I go with go4 and now says new 079 firmware available, then the same fails.
I would do a factory reset if that were possible. The drone has no gimbal, bought as parts or repair. Error is,
200 with check USB port, and contact dji.
There is a RID number in the go4 info screen.
I looked with BluTooth but don’t see drone as in broadcasting ID number.
What app is recommended to search for aircraft broadcasting?
Any thing I can try to finish the firmware update process?
The progress starts with downloading, then transmitting, the upgrading but upgrading fails.
Reactions: Felix le Chat
Yes Egor. I installed a gimbal, whether it mattered but….
I turned the drone on afterwards and the incompatible or inconsistent firmware message to upgrade came up.
I repeated the process and noticed a message while it began updating. ‘Update log is empty’.
This time it was paused at 74 percent. Then bam, it said Update complete, restart the vehicle.
It restarted and I had not notes, and checking firmware gave latest versions.
I am still redoing the Gimbal since it was overload condition. I find two motors that cause the gimbal joints to show uneven spacing.
Causing unbalanced forces.
First pic. I pushed motor in a bit to much to level it. Now relieving the drag on the coil side. Using the motor puller.1000013479.jpg
I remember now I have to agree with Felix!
No.1 You must have a bunch of time and money First thing I would do is get a NEW Gimbal. You are going to Bleed money on that repair!
Reactions: StantonZ
Spag
