no need to worry, they will outlast the electronics with absolute certainty.
im curious now what maintenance are you referring to?A scheduled maintenance, is a well known money saver practice (unless they steal your money, with absurd prices with spare parts).
Moreover with flying machines it's a must, since you can't park on the side of the road, when the engine failure happens
Last but not least, a brushless DC motor, has electronics inside.
really? so what does the electronics inside the brush-less do?
im am very intrigued by your comments
To rotate, an electric motor needs a rotating magnetic field, then an AC current
Using DC, there are only two ways to obtain the above.
Simplifying...
1) With brushes, changing sequentially the supply to windings, in which the DC current is applyed (mechanical switching).
2) Without brushes, an AC synchronuos motor, where the AC is produced by an electronic inverter circuit (or electronic switching)
[QUOTE="mpa, post: 244313, member: 14929"
ill give you my mavic if you could find an inverter in the mavic motors
when was the last time copper failed?
there is only 2 moving bits, and they are the bearings
