Moving from Mini 3 pro to mini 4 pro - what can be re-use?
erezgur
Israel
Hi,
I'm moving from the mini 3 pro to mini 4 pro and wonder which of the following equipment of the mini 3 pro can be used with the mini 4 pro:
1. Batteries (I believe they are the same)
2. Propellors
3. DJI RC (I have the RC with the builtin screen, forgot the exact model name)
4. ND filters
5. Batteries charger (for 3 batteries) from the mini 3 pro fly more kit
Thanks,
Not sure about propellers, everything else should still work. Check the number of cycles on your batteries and whether lock tabs have cracks.
Thanks!
The batteries looks the same, no cracks on the tabs. I just checked on of them and it's working with the mini 4 pro.
It looks like the ND filter does not fit the mini 4 pro, and I'm not sure about the RC and the propellors - I'm interested to hear if someone can confirm that I'm right.
I was under the impression that the filter mount is different.
And I also thought the batteries were compatible one way but not the other (can't remember which way).
The props I also thought were different.
But your controller, charger, and case will interchange for sure.
What @Bad Santa said... have to buy new filters. The Mini 3(P) filters do not fit the the M4P. Know first-hand.
The rest of the list is all good.
As far as I know, the RC1 with the built in screen is not compatible with the Mini 4 Pro. You will need either the RC2 with built in screen or the RC-N2/N3 that you use with your own display device.
Chris
@Chrislaf is right on the controllers. The RC won't work because you are moving up from Ocusync 3.0 to 4.0, which requires the RC2 controller or RC-N2/N3.
dvkhamtruocsinh
