M mayron New Member Joined Jul 6, 2019 Messages 2 Reactions 0 Jul 6, 2019 #1 my mavic pro does not turn on cooler, error (aircraft encoder error (0x1000000) what can be
W Wokka Wokka Active Member Joined Apr 14, 2019 Messages 26 Reactions 8 Location Melbourne, Aus Jul 7, 2019 #2 Does the fan spin easily when you move it by hand? (or when using a small thin tool to rotate the blades?) If not it could be as simple as the fan dying.
Karl D Well-Known Member Joined Aug 24, 2017 Messages 124 Reactions 83 Age 57 Jul 8, 2019 #3 Ive had a few where the grill behind the gimbal is slightly deformed causing the fan to stick. a slight realignment sorted it.
M mayron New Member Joined Jul 6, 2019 Messages 2 Reactions 0 Jul 10, 2019 #4 I removed the cooler it works by connecting directly to a 4volt source, but the drone does not work
