Name this connector
Will042082
What type of connection is this? This is the Mavic AIR board and the antenna cable that runs to it and connects to the board.
0D8D2908-D362-4E07-8D7A-9DAC8658700F.jpeg F58594EA-2DAD-4056-883D-68A0AEB0AB25.jpeg
I purchased u.fl and that’s definitely not it. Then I got mmcx and it appears to fit, but my male end has a pin and it appears the boards female end does as well.
738664C4-52AD-46F3-8C6C-22C36549EEE4.jpeg 5F1BF048-D2C0-47D8-B34E-EE0B7D08D0DA.jpeg
Can someone PLEASE confirm what type of cable/connector I need to connect to the board.
So the stock DJI antenna connects to the main board via an aerial connection? Just confirming I’m understanding you right.
Is that connector called a ufl iPex? I find so much of the cables I already have and just want to make sure 3rd times a charm when ordering.
For reference what I’m looking for is a couple of pairs of 6-12” SMA to what appears to be a FR113 IPEX port based on your link above. The board connection this needs to connect with is here.
The stock antenna that currently connects to it is this
Just updating the threads I started. I’m pretty confident the exact connector is a u.fl MHF4 which is .81mm. I’ve ordered a few and will update to confirm.
Irish_Sinner83
