Nanuk 910 Case for MM
Dharris6891
NE AZ
I received a new Nanuk 910 case with the MM fly more foam insert from my wife. So far, I really like it. It is much bigger then the original case, to me that's not an issue, it'll still fit in a hiking pack. The foam is cut well and everything fits in nice and snug. It came with a small extra piece of foam so I cut out some "risers" to place under each end of my MM (1/2 thickness of a "layer"). The keep a small air gap under the drone and lets the lower props rest freely and not be compressed. When it's closed up There is very little to no pressure on the upper props. The accessory storage gives me a lot more space then the original case for sure. I have 8 or so spare sets of props, the screwdriver for them, 2 otg cables, a 6 pack of lens filters, a lens cloth, USB micro SD card adapter, and 3 charging cables. This is in JUST the accessory area. The case also holds up to 7 batteries, 8 if you leave one in the drone itself. It's nice that the RC fits with the sticks still attached, its more convenient for sure. It's a very well built case, the foam is cut accurately, and you can get it in a variety of colors. I know it's probably been reviewed prior to this, but id highly recommend it for a MM. It seems it will provide great protection while being able to keep everything I need in one place. I'll probably have a friend cut a stencil with my name/contact info so I can permanently mark the case as well.
djimini3
