my mavic pro fell from sky, replaced both rear arms, i cant cant calibrate the imu, i get a error 71. i search site and  cant  find  anything  the will advise what to do.
thanks in advance
ray
			thanks in advance
ray
i found this on ebay , does this have the fan on it?Do you want to try it yourself? The board, without fan, is $69 - $89 online. You will need to do 20 solder joints if you buy the board alone. To save yourself some time and trouble, you could buy a new board with the fan and compass already soldered on like this one:
DJI Mavic Pro Drone - NEW Flight Controller ESC, Power Board & Compass | eBay
Can you take a picture of your work and post it up here? Take the pictures as close as you can to the FC board and all the solder joints you did. Dont order the FC board yet.
well i didn't cut the wires from the rear arms, i just cut the wires about 1 inch from the board then solder them together, so the rear arm wires can still reach the main board. hat would you charge at most for the repair?
