New guy
Hey all, new to the drone world, but I flew a few cheapies, then upgraded to DJI mini 2
Since you live in Canada and since you've had some cheapie drones, you may not be aware that there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Wh
Thanks for the tips , lol I have already lost one battery due to crash in water, I was surprised that it survived, currently i am assessing whether to rebuild battery, I have already jail broke it, (legal up here), and I actually have a drone pilots license, in Canada no rfid identity chip, and little to no enforcement where I live. But I hear there is talk of bringing some type of program like that in. I bought the drones to be a better electrician as I am a millwright and have good electrical knowledge, but not best and this is a really good way to learn with interest.
Reactions: LoudThunder
Wh
Welcome to the forum from a retired electrician. I learned a lot from all of my fellow tradesmen over the years. Have fun with the drones. Check out a Yuneec H920 for size. It is a millwright’s drone.
That's is definitely a big drone, how do they handle? I like the idea of hoisting a medium format Pentax z into the air , and the price was kinda reasonable I was surprised. And can It be hot rodded?
dojin23
