New Mavic Air Firmware Released
SparkPlug
Overview
  • Date : 2019.02.28
  • Aircraft Firmware : v01.00.0560
  • Remote Controller Firmware : v01.00.0200
  • DJI GO 4 App iOS : v4.3.12
  • DJI GO 4 App Android : v4.3.12
What’s New?
  • Aircraft: Optimized battery level algorithm.
Reactions: ShermanFlyer
If I had a battery that went from 54% to 0 instantly (from reading, this sounds like a common problem), how can I ensure that all of the batteries I own get updated (assuming this update has anything to do with the battery’s firmware as well)?
If battery firmware does in fact change, you need to cycle each battery through the Aircraft (power off in between) and you will be prompted each time to update that particular battery's firmware.
To my knowledge that is not a common problem though, I have read a few accounts on this forum but that's about it. It's also impossible to know for sure how those batteries have been cared for, and that sort of thing also happens to be a symptom of an abused battery or a cold battery (not saying it is in every case), and there are lots of folks who fly outside of the drone's advertised operating temperature range. No doubt there will be a small number of defective batteries kicking around though, as with anything. I personally never ran into that issue but my sample size is only 3. All you can really do is keep firmware up to date, not fly below 0C, and use best practices for battery care.
Reactions: JSKCKNIT and pvs
First, I've never run into the battery issue.
When I updated the Mavic Air firmware this morning, I wasn't offered a firmware update for the battery that happened to be in the drone.
Based on that, I doubt whether a battery firmware update was released along with the drone firmware update.
The drone firmware update might or might not have addressed and/or resolved the battery issue, it's hard to tell from the brief description provided by DJI.
I took the bird out for a short test flight after the update (short because it's cold where I am!) and didn't notice any change one way or the other. Then again, I've never had the battery issue.
Larry
Larry
The person I quoted just seemed to be wondering how to update the batteries in the event of a firmware change, at least that is how I interpreted it. To my knowledge there was no battery updated released and it sounds like your experience also helps confirm that.
It's MUCH too cold here to fly, -29 C (-20F) is the forecast lows for the weekend :mad:
Reactions: larryc43230
Your cold beats my cold. I was whining about 0 C (32 F). :D
Larry
Reactions: CanadaDrone
Thanks for the replies. The battery that this happened with was brand new. It was the first flight on it. It was around -10°C though during the flight. That battery was kept warm right up until flying - and the original battery never had any issues at all in the flight prior.
Thanks for letting me know how to get the battery firmwares updated - just in case this is needed.
If you were flying in -10C that is well below the safe/recommended operating range of the drone/batteries - I would guess cold weather was the most likely culprit in this instance, because the sudden percentage drop is a common symptom of that. I can't say for sure though obviously (same thing happens to smartphones in the cold). Some people have success flying in the cold but there are also many people who have had issues flying in the cold, it's definitely riskier and not something I ever do personally. If you do not have this issue when the weather warms up, you'll have confirmed it. If the issue persists even in warm weather, could be a bad battery.
You bet. I’m hoping that’s what it is. Only time will tell. It’s been so miserably cold here that I haven’t had a chance to fly since that happened.
-20F? :oops: That's much too cold to do anything except move much further south. ;)
I don't disagree :) February in the Canadian Prairies this year set records for extended cold temperatures, it's not always like this but it was a pretty cold month. Nov-Jan were very warm, so now we're paying for it haha. There's hardly any snow thankfully, which I dislike a lot more than the cold.
Reactions: cbest
My MA dropped from the sky into the Pacific Ocean when the battery went from 44% to 0% in less than 1/2 a second. Luckily, I was able to retrieve MA and with DJI Refresh, it was replaced on the spot. Having said that, I had a lengthy discussion with DJI, feeling that I should not have been charged for a replacement. In other words, I should still have 2 replacements on refresh, which I don't. I am now very fearful of flying over water due to exactly your question. I don't know which battery was in the aircraft that day. I guess I'll have to rotate through all three while I still have time left on my Refresh acct. If you hear of any update, please let me know. Thanks.
Larry
Egen you change the battery to another one, you’ll be promted to upgrade software again. It did that today on my bord and it indicates to me that it Is the battery that is updated.
When you change the battery to another one, you’ll be prompted to upgrade software again. It did that today on my bird and it indicates to me that it Is the battery that is updated.
Thanks for the heads up; that's interesting.
Yesterday, when I updated the Mavic Air's firmware, there was no separate notification about battery firmware. However, the battery that happened to be in the drone did apparently have its firmware updated.
After reading the above message, I inserted another battery, fired everything up, and was notified of a firmware update. The notice didn't mention the battery, but I did get the message about "Incompatible firmware", and an update took place.
I shut down the bird, inserted another battery, and got the same firmware update notice. Rinse and repeat for my fourth and last battery.
I'm guessing that whenever the bird gets a firmware update, the battery that happens to be in the drone also gets any firmware update that's required.
I wish the updating process included some message that the battery firmware was also being updated, so I would know I also needed to apply an update to my other batteries.
Larry
My experience today was less then stellar. Went to fly, got notified of the needful upgrade, tried to do it, but got an error. Tried once more, and it failed again. I WAS able to fly anyway, but I had to plug the drone into my PC to upgrade via DJI Assistant. AND...just now I'm also having to install a Precise Flight DB upgrade...So far so good on that :) Am also being prompted with the "firmware incompatibility" popup.
Reactions: pvs
Thank you early adopters for your reports. I'm happy to be aware of any hiccups in the process, if there are any. Your input has been very interesting.
I saw that, but they are both relevant threads. I hope they can be combined, as I do not wish to duplicate my input on the other thread.
Anyway, I can confirm that this update needs to be done on EACH BATTERY. I used DJI Assistant, and there was no place where it stated that it was doing anything to the individual battery. But I cycled through all three of mine, and needed to update each time.
Something definitely also gets changed on the MA, though, as once it has been updated, DJI Assistant throws an incompatibility error with the old batteries. Again ... it doesn't state that it's the battery. It says: "Firmware incompatibility detected between some modules and the current device. Update your firmware?". So it seems they're talking about the battery.
Anyway, on to see what happens when I connect with DJI Go4 ... ;-)
Tlaw
