New Member New To DJI Mavic 4 Pro
Greetings from Birmingham Alabama USA: welcome to the forum! We look forward to hearing from you!
Welcome from the Beautiful Pacific Northwest in WA.
You're gonna have a lot of fun with that drone.
Please follow alll safety rules; pass the easy test and get your TRUST certificate and register the drone with the FAA. You may have already done all that.
Hello from the Crossroads of America zman444.
Nice to meet you. 🤝
Welcome to the Forum. :cool:
Reactions: LoudThunder
I'm a proud new owner of a Mavic 4 Pro.
If you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
First, if you have not already done so and you want to fly your drone recreationally, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). This Link is to the Pilot Institute Web Site where you can get your TRUST Certificate. (FREE…)
Next, your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under the 44809 Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Ohio, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Reactions: MA2 317
resection3d
