New member
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you might have. Search the forum using key words and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
I'm a new to this forum. Love to fly my DJI Mini 2
Since you live in Italy, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
VictorioMol8
