New MPP Owner - Help Requested. Thank You!
6stops
Hi all,
Happy New Year. New MPP owner here!
Problem?
I took my first flight yesterday but I had a couple of issues.
- The Max Altitude, no matter what value I inserted (0-500m), would revert to zero (0) each time. I was restricted to 120m.
- When in-flight, I could not enter the camera settings menu, no matter how many times I pressed on the relevant icon on-screen. And so I was unable to set to Portrait Mode, adjust shutter speed and so on and so on.
Was unit in a crash?
No
What have you tried so far?
Installing all up-to-date software and firmware
What device are you using ( iphone , ipad, Samsung , etc)?
iPhone 7 plus
What firmware are you running ( aircraft, remote controller)?
RC
What Go app version are you using?
DJI Go 4.0
Any modification? (if so what)
N/A
Did you change anything or install any apps? (if so what)
N/A
Do you have a video or pictures of the problem? (if so post link)
N/A
Hoping someone can help! Thank you!!
Was the Mavic connected while you tried this?
The setting is stored in the aircraft so it won't take unless the drone is connected.
btw .. If you are a new flyer, 120 metres should be more than enough.
And if you try it on your desk, without starting the motors, how does it work?
first of all the height restriction it is set at 120m or 395ft as that is the max safe altitude in the uk to comply with the regs you should not be trying to alter this
Are you flying with the RC and you phone is the display or are you flying in WIFI and only using your phone ?
tflys78
