New to MP but lurking for quite some time! GWL NY
smokinsoljah
Greenwood Lake NY
Hey guys! Happy to be here! just introducing myself! Names Big Ben from Greenwood lake ny! Im a wizard when it comes to anything electronics (passed through genes (father was a ham radio repair phenom)). I specialize in rc, airsoft, 3d printing, and solder work and have been in those fields for over 30 years. Expect to see some cool stuff coming your way! I recently have started acquiring many different versions of the minis and well as other models to start making charging/display drone adapters or custom domes for EVERY model i can. In the process of making a tutorial atm to make a pretty cool mod for your mini v1/v2 displays with dream leds and micro controllers!
Welcome to the Forum!
Yes, we will be in touch!
I learned of basics from my dad.
I had a novice license when I was in 7th grade. But the code thing wasn't working for me.
I been wanting to play with 3d printers for a long time. Also been playing with Air soft stuff, etc.
Sorry this supposed to be your intro. :rolleyes: :)Thumbswayup
Rod ..
Wow, what you said, went right over my head…
But you wrote that you only recently started acquiring your collection so I presume you are a newbie drone pilot…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). If your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
In case you do not have the user manuals for your various drones, here is the link to all the drones sold by DJI and their downloads…
Fly On and Fly Safe…
Rod ..
sounds like well get along just fine! look forward to conversing with ya!
MAN! What a response! now see this is what forums need more of and why i finally jumped into this one! So successfully due to this forum before i even because a member i learned everything i needed that you've stated. Registered all 5 of the djis Ive acquired in the last 2 weeks and have successfully dismantled and repaired everything that was needed with them (all bought 2nd hand of fb marketplace and all needed work). 2 mini v1's,1 mini v2, 1 mini v3, and a mavic pro. Have all currently 3d scanned so i can make charging domes for all. Also studying atm for my trust and then going for my business license just for s&g if you get what i mean! Hours and hours and hours of research in and honestly if i would seen you respond to someone else like this it would've saved me hours! hahah Thank you so much for accepting me into the family!
WELCOME!
RobertCNewman
