New to the forum
Greetings from Birmingham Alabama
Good evening all.
Just upgraded from my mini 2 to a mini 4 pro, but not flown it yet due to being in a temporary frz. It should clear tomorrow so I can get started.
In Liverpool so would be good to meet some new pilots in my area.
A big welcome to the forum from the UK! Unfortunately not near you. I’m in Norfolk
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Reactions: Mrktn and MA2 317
Hello from the Crossroads of America thelaird1.
Welcome to the Forum. :cool:
pppca
