New York Central Railroad, abandoned Power Plant
cheezstake
Another windy day on the Hudson river. Got a few good clips of this abandoned power plant. The building is supposedly under construction, and there is a ton of scaffolding inside, but it has been that way for a very long time.
Well Done.
Question: Where were you piloting from?
I'm assuming you had been moving locations as I suspect you'd lose connection as you approached some areas of the building that would block signals. But getting the water side would appear to be blocked unless you approach by boat... Curious on this one...
If you look to the left side of the screen in the first scene with the text. I am under the big tree by the fence near the water. I pretty much stayed there the majority of the time.
Impressive considering you flew down the other side of the brick building. Balls! I would have surely thought a lost connection would result, but perhaps there is enough air gap through that building to let signal through! Nice!
Loved the video.
Yea it's in Yonkers.
Leonardobusss
