Newbie question
Afterfive
Was flying mini mavic battery started going bad .return to home came on but I wanted to just land it right there held joystick down would not land why? Other wise it was buy a tree and was afraid to let it go up. I would think I could always land it. Any info thanks mike
Just to check, did you cancel the rth before trying to land? Rth overrides manual landing.
No, I suppose I was to hit return button I was afraid that would just do the same I just held joy stick down.at least that kept it from going up but would not land.
Yes still flying. I was under a pine tree and also near water trying to record girlfriend fishing. But thanks to info here . I now realize as soon as I heard alarm for battery should of hit rth button.right away.but since I did not I just held left joystick down continuously. It kept spinning around and around but at least did not go up much higher than 4 ft and I was able to move directions and it finally landed
Reactions: Capt KO
Should watch the battery level and have some spare time when you land. It’s also better for battery life. However If flying close at the end of a mission and the alarm goes off don’t panic. Just stop hover and make a plan to return. RTH is not always the best plan as the drone will climb and use battery. Take your time and make a plan to return and or land.
I once landed on 1% and the Ap had been screaming at me and warning it was about to launch RTH which I kept cancelling. The MP was only a few metres away and a few metres up. As I said bad for the battery life. Better to land with 10-20%. Enjoy flying P
I had just flew a few mins early battery was at about 25%. Did not realize battery would drop that fast.and that the rth would activate automatically. When battery went low.I have not been in and open environment to use rth option. I just forgot that I could just touch rth button to hopefully stop it.and not hold it to enable
austinabrady
