Nexus 7 Tablet
  • Thread starter Thread starter Deleted member 125445
  • Start date Start date
It will be borderline capable anyway, I was using one with Phantom 3 but the app grows ever large and more demanding.
Eventually it was only usable with cache to phone turned off and everything else closed down.
You could get a cheap larger Chinese phone with ample ram for it and only connect by wifi when you choose.
Op I just bought an Asus z8s 8 inch tablet uses from eBay. You can get a good one for $100 bucks. It has a high resolution screen and a metal build, plus lte.
Thanks for that answer. I will probably just use my Google Pixel when the drone arrives.
Thanks, the consensus in this thread is that the Nexus 7 is not a good choice. It looks like I will call upon my first generation Google Pixel. It should work.
Thanks, my other option is my phone. I just thought maybe my old tablet could be put to use.
I improvise.
It is definitely not compatible. I even tried apk and it would not load that either. I am going to try a crystal sky next.
Did you allow from unauthorised sources.
I'd be surprised if you couldn't install the app and maybe use it for setting things up - register etc if you were waiting on something better.
pauljj2
