No sound after filming
Hello,
I was filming last weekend a nice gathering of dancers. Unfortunately when we were watching the movies, there is no sound.
Any help will be appreciated
You recorded movies on the MPP, played them later, and there's no sound ?
Totally normal, no sound recording on any DJI drone.
when I want sound on my mini 2 while I'm flying I record the sound (music in his case) with my other mobile phone then put the two together in post editing, this is an example.
I don't understand. In the past I had sound recorded while shooting. Even sometimes on high winds, the sound of the wind is part of the recording
Check the Go4 app.
There's a setting to record audio while recording the cached image to your device.
I haven't used the Go4 app in a while, but used to be there.
Check the Go4 app.
Yes, sound at the controller.
If that's what the OP means then it probably got switched off, or an update might have reset it to possible default off.
It's mostly used to get voice notations, possible if drone is some distance away to get some ambient sounds, unless you want drone sound at times . . . but really you'd be better off getting ambient sound from some other (better) audio recording method, or from an online source of sounds.
As a matter of interest, does the Fly app allow recording of ambient sound at the controller point ?
I have 2 drones using Go4 and controllers, have never used the feature though.
Might do so just for the learning curve.
No. Any recording needs to be done separately from the DJI Fly app.
Reactions: MAvic_South_Oz
BuzoLibre
