Have a look at your rpm figure with these c-f prop's. I put carbon-fibre props on my Mavic Pro Platinum and that reduced the rpm in the hover from around 510 to 470 rpm. Slower prop's make less noise! Careful tho' - depending on the brand - you can get some c-f prop's that are prone to shatter if they hit something. You need a prop' that will at least stay together with a tear in it 'till you can get the drone on the ground!Great News!
I discovered Carbon Fiber Propellers by Bower yesterday for the MA. Comparing the designs, I think the standard props are noisy due to the flex and therefore the need for a larger surface area and need for the lower trailing edge to have a pronounced lip. When you feel the stiffness and quality diff, you will be upset with DJI for failing at this step of design. The originals feel like a toy and sound annoying.
Sound Meter Test: taken from TO point straight up.
Standard. Carbon Fiber
42db. Amb. 44db. Ambient reading at time of testing.
79 T.O. 77 Take off
72. 25 ft. 70
65 50 ft. 65. Airplane was going by
60. 100 ft. 55
The best differences were noted in flight when aircraft was not directly overhead. Quieter and the sound was not so annoying. It actually sounded good compared to the stock. Maneuvering was quieter as well. Max speed was unchanged in the brief flight test.
I have this thing about carbon fiber props from trying them on my phantoms and just don't care for them . They will cut you way faster and shatter . Me think I will stay with OEM props with what I have .
Mine makes noise, hope that helps.Has anyone made any discoveries lately regarding the noise of the mavic air?
