On its very last leg?
wco81
I tried to fly today. Pretty strong winds but I was in a place I was unlikely to see again so I went for it.
Not long after takeoff I got a wind warning, telling me to land it. I just recorded a 3-4 minute video, took some panos, then recorded video to move to a different location, where I did a couple more panos.
In the second location, the gimbal was going haywire. The warning was that the gimbal was overloaded. First warning I think was that there might be an obstruction for the gimbal to move around normally but then it said the gimbal motor was overloaded.
I've see this behavior before but here I had to abort my first two attempts to do 180 panos because it wasn't leveling the camera and thus it wasn't taking any pictures. I flew it slightly to a different location and it leveled enough for me to finish the panos and land.
Would gimbal motor be overworked fighting the wind? The wind wasn't the worst I've seen. I'd estimate maybe 20-25 MPH gusts. In other windy conditions, a few years ago, I never saw the gimbal fail to level out.
So I'm wondering if my M2P is showing its age. Despite having it 6-7 years, I don't fly a lot, only when I go on trips so that means on average, maybe 15-20 flights a year using up most of a battery. None of my batteries show sign of swelling but it does seem like they draw down faster than they used to.
The other thing is my controller, which I had fully charged the night before, showed 43% even as I completed this one flight, which ran maybe 10 minutes, drawing the battery down to 25-30%.
But the controller battery drawdown surprised me, never saw anything like it before. It would only show like 92-97% when fully charged.
Only reason why I kept it is because of shortcomings of newer models like the Air 3S, without a variable shutter and with the Quad Bayer thing which put off many people.
I was kind of waiting to see what the Mavic 4 would be like but now the price is likely going to be way more than I would pay.
I may have no choice but to buy any newer model that I can get my hands on.
Reactions: Cafguy
No.
This is normal as they age Best to use them up in a couple years really. It all depends on how you care for them!
Its been a few years for Your battery it's acting its age. You will need to replace it in a while. do it yourself its very simple.
At 125 Waiting for the Mavic 4 Pro may not be the best plan now. (Sorry) :rolleyes: . Yours is NOT showing age and you simply have some simple care and cleaning to do.
Gently..Very gently, Take the tip of a finger and move the gimble around. You want to "feel" for anything..even the slightest grit feeling. If you feel any "grit" at all, You need to gently blow out the gimble with air..., set the air WAY down and DO NOT use "canned" air!
If you do not feel any grit and I know this sounds crazy BUT re-flash all of your firmware and test everything again.
Reactions: wco81
Lithium batteries gradually lose capacity with age and use.
You can check to see how much capacity has been lost in the battery settings in the app.
Compare the capacity of a freshly charged battery with the number printed on your battery label to see how much has been lost.
Your controller battery also runs down with age, but you can't check that in the app.
JulianIHC
