One propeller less fluid when mavic is shut off
Fandango80
France
Hello, I bought a mavic air 2 but I will not be able to use it for a few weeks. I still mounted the propellers correctly but I noticed that (when it is off) they always rotate smoothly but one is a little less fluid than the others (front left). I mean that with the same force the others do more laps. Doesn't sound serious but can it be a problem? Thank you
it may just be that the tolerances of that motor are slightly different to the others ,remove the props and just turn the outer bell of the motor, and compare it to the rest ,if there is an obstruction inside it will feel different and possibly sound different to the others also if there is an issue then it would feel hotter than the others after it had been running
LeoleoLeo
