Pano load time and auto abort
BaldyBoyBilly
new jersey
I noticed a couple of items while taking panos and wondering if there are settings to address:
- the capture rate is extremely fast, there appears to be no dwell time/wait time between the move and capture. Can this be increased to allow camera to settle?
- the processing time of the captured images is slow…takes much longer than capture time…which should not be an issue. However, if the sticks are touched before processing is complete, the system aborts and images are deleted. So the bird cannot be repositioned during this dead time.
I don’t recall that on my P4P V1.
There is no need to dwell/wait between the move and the capture. The images are already sharp as tacks! Processing time is only 35 seconds, after a 40 second capture time (Autel takes 4.5 minutes just to take the spherical pano stills and can't stitch them, and blanks out the FPV during the stitch on other pano types!). Total time, from start to finish, is 75 seconds per stitched HiRes 50MB+ pano. While it generates the cancelation of the Pano message if the sticks are touched, in each case, mine completed the pano anyway, and all images were retained. Bird cannot be repositioned during the 75 seconds. Mavic 2 Pro operates the same way, except it's 26 images take 30 seconds to shoot and 30 seconds to stitch because it is a low res 12MB stitch. Only settings available are choosing either JPG or DNG if you wish to keep the original images, as you cannot select both! These settings are completely independent of the settings for still photos, and can only be set when in the air, choosing pano, and then selecting camera settings.
EscRen
