Phone screen refresh rate 1hz
Status
Not open for further replies.
dsingfsw
Problem? The screen refresh rate on the Galaxy screen is approximately once per second, too slow to safely fly from.
Was unit in a crash? no
What have you tried so far?: Updating all firmware, making sure firmware on phone and Mavic match.
What device are you using? Galaxy S6
What firmware are you running ( aircraft, remote controller)? newest
What Go app version are you using? 4
Any modification?
its all a stock unit
Did you change anything or install any apps? I haven't flown in about a year, prior to this I've had zero problems with the Mavic. I followed the prompts to update firmware and now have a phone screen refresh rate that is too slow/jerky to safely fly from. It updates about once a second rather than the standard approximately 30hz.
Do you have a video or pictures of the problem?
No I don't sorry
I'm wondering if this is a bug in the latest firmware, if anyone else has experienced this problem or knows of a fix.
Thanks.
Kavin
Your title says one problem (1hz refresh rate) but your description says another (won't turn on).
Same post with replies can be found here:
This duplicate thread locked.
Reactions: dirkclod
Status
stevemaller
