Phone Size For Mavic Air
GeorgeRace
Can someone please tell me what is the maximum size phone that will fit into the Mavic Air.
Thanks,
GR
Thanks,
GR
Here are the specs for the controller, the device capacity is at the bottom.
Operating Frequency 2.400 - 2.4835 GHz
5.725 - 5.850 GHz
Max Transmission Distance (unobstructed, free of interference) 2.400 - 2.4835 GHz:
FCC: 4000 m
CE: 2000 m
SRRC: 2000 m
MIC: 2000 m
5.725 - 5.850 GHz:
FCC: 4000 m
CE: 500 m
SRRC: 2500 m
Operating Temperature Range 0℃ - 40℃
Transmission Power (EIRP) 2.400 - 2.4835 GHz:
FCC:≤26 dBm
CE: ≤18 dBm
SRRC: ≤18 dBm
MIC:≤18 dBm
5.725 - 5.850 GHz:
FCC: ≤30 dBm
CE: ≤14 dBm
SRRC: ≤26 dBm
Battery 2970 mAh
Operating Current/Voltage 1400 mA ⎓ 3.7 V (Android)
750 mA ⎓ 3.7 V (iOS)
Supported Mobile Device Size Max length: 160 mm
Supported Thickness: 6.5-8.5 mm
Supported USB Port Types Lightning, Micro USB (Type-B), USB-C
An iPad Mini 4 will fit, so any modern phone should fit (assuming it's not in a case).
5.725 - 5.850 GHz
FCC: 4000 m
CE: 2000 m
SRRC: 2000 m
MIC: 2000 m
5.725 - 5.850 GHz:
FCC: 4000 m
CE: 500 m
SRRC: 2500 m
FCC:≤26 dBm
CE: ≤18 dBm
SRRC: ≤18 dBm
MIC:≤18 dBm
5.725 - 5.850 GHz:
FCC: ≤30 dBm
CE: ≤14 dBm
SRRC: ≤26 dBm
Battery 2970 mAh
Thanks, that is exactly what I was looking for.
GR
Will an iPad mini 4 fit in the Remote horizontally ( the long way)?
Yes. You'll have to wedge it into the remote controller like this:
Reactions: JakeS
It fits great but does take some pressure to push in and you can easily pop the little square plastic cable holder out so it sits better that I show in that video...
Interceptor650
