Photos not going to Tablet
Hi
The last two times out I took photos
And they were on the on board sd card
but not on my. S2. tablet.
Video I took was there But not the photos.
. Any thoughts ?
If you have inserted an SD card in the port on the side of the M2 that would be default. It is also much more efficient in power use if the images are stored there.
Honestly not completely sure as I gave up phones and tablets some time ago for the CS. It could also vary among tablets and be different in Android tablets than Apple tablets.
The CS stores low res copies. The RAW and jpeg images as well as the 4K video are stored on the SD card in my drone. I change the card, 60GB, every flight to prevent loss of images in a worst case scenario.. . It also saves battery power and makes the drone more responsive since it is not using power and transmitter to send images.
True....
Check setting on controller - may have turned Cache off ??
If you're shooting RAW only you wont get any images downlinked because the app doesnt support DNG.
There's also been a bug on Android for about 2 years now unfixed where auto sync rarely works. You have to go into the play icon (right hand side) and manually download.
Reactions: crlmjohnson
Check out the "Auto Sync HD Photos" settings in your DJI Go camera settings. Here you can configure what you're looking for.
fiweli
