Used to be a professional photographer (Past Tense), getting back into the swing of things in regards to Videography and B Roll clips... let me get your honest opinion so that I may get better at this new world that I’m in...Please enjoy...
nice video cool music, can yo
Are you tapping the screen to focus it mate?
Also look at You tube how to slow down and smooth the yaw.
Have you checked out cinemagraphic modes or tripod modes?
Have you invested in filters?
Otherwise some nice footage bud!!!
Hi,
Max res i can get on YouTube is 480p did you upload a small version of the file?
Seems to be a little overexposed in some locations or did you record in a flat profile? ( D-Cinelike or Dlog ) looks like it needs some colour grading too.
Thanks,
Wes
You need to post to youtube with 1080p resolution. It will look a lot better.
First, like most people have already said, make sure you tap the screen to focus as soon as you start recording. As for settings, it's really down to each individual user, what works for one person will probably be different than the next person. But this is what works for me. Firstly, always shoot in 2.7K or 4K, both are good, on the firmware that I use you can't use the zoom option with 4K, so I use 2.7K a lot just because I can use the Zoom function. Use manual camera settings. These can be subjective but at the very least make sure the sharpening setting is set to +1. If you have the sharpening set at 0 or below, you will get fuzzy patches in your video, especially in areas of the video that have a lot of contrast. ND filters are also good, they do nothing for the overall quality of the video but they let you use lower ISO settings that are known for better video. Set the ISO to 100 set the frame rate to24 or 25fps set white balance between 6500 - 6900. If you don't use ND filters, your ISO will need to be between 800 -1200 on sunny days to get anything like good video. This can make the video look jerky and sometimes have a strange flickering effect on it. Using ND filters stops all that. These settings work for me, others will prefer different settings but it's a good place to start... Then use trial and error until you find the settings that work for you.Used to be a professional photographer (Past Tense), getting back into the swing of things in regards to Videography and B Roll clips... let me get your honest opinion so that I may get better at this new world that I’m in...Please enjoy...
Safe flying!
Thanks Ren57...Super helpful.
What I meant was when I went to play the video on YouTube, the mas resolution I could select was like 720p. Not sure if you uploaded in that resolution.I have my MP shooting in 4K and post process in Premier Pro CC in 4K as well. Should I bump it down to 1080p in Premier Pro before I export?
totally agreeYou're confusing ISO with SHUTTER SPEED and the effect of ND filters on exposure. You always want to keep your your ISO as low as possible, 100 when shooting outdoors in the Sun. This is because digital cameras use amplification (gain) to increase ISO sensitivity, which also amplifies the noise that's picked-up from other circuits in the camera and drone. At even higher ISO's you not only have heavy noise but also loose detail and contrast. But outdoors on a sunny day you should never need to go higher than ISO 100.
The rule of thumb is to have your shutter speed 1/(2xFrame_Rate) for smooth video. So if you're shooting at 30 FPS your base shutter speed should be 1/60. (I always shoot at 30 FPS and then conform the clips to 24FPS in Premiere; I feel that the slight reduction in playback speed helps smooth-out the video.) This is a guideline though, not a hard and fast rule. You can increase your shutter speed to reduce motion bur and make motion in your video sharper, but the faster you go the "twitchier" your video will look. Sometimes you might want that kind of effect, but not generally with drone footage. See this article for more on shutter speed vs frame rate: How Shutter Speeds & Frame Rates Can Be Used to Change the Look & Feel of Your Film. Note that you can safely double or triple your shutter speed before jitteriness becomes apparent.
You also want to keep your shutter speed in the range of 1/60-1/200s to avoid "jittery video" (though there are exceptions). Because the Mavic has a fixed f/2.2 aperture, even at ISO 100 you might need shutter speeds as high as 1/4000, even 1/6000s. More info on the "exposure triangle:"
What an ND filter does is cut down on the amount of light reaching the lens, so you can reduce shutter speed without changing ISO or aperture. An ND4 filter will allow you to slow your shutter speed 2 stops (from 1/4000 to 1/1000), ND8 provides 3 stops (1/4000 to 1/500), ND16 provides 4 stops of light reduction (1/4000 to 1/250) and an ND32 provides 5 stops of light reduction (1/4000 to 1/125, which is in the right ballpark).
Its worth mentioning that some ND filters (Polar Pro Cinema Series) add circular polarization to the ND filter. When adjusted properly, these filters can darken the sky and cut down reflections off water, glass and other surfaces. You rotate the filter with respect to the Sun's location, so if you rotate the drone (yaw) you might need to land and re-adjust for best results. (see .
(I don't know how to enter a link without video getting embedded, sorry)
