Post vibration plate repair issues
Davemooney
Had crash broke vibration plate, camera still worked after crash so I just ordered new vibration plate assembly. Post repair it goes to hove position and the quicky drifts right and camera not working, vision sensor error comes on screen.
Probably 2 separate problems.
Make sure you have both ribbon cables plugged in to the gimbal PCB. They should snap in.
Are you getting video? Does the gimbal calibrate?
Ok took it apart, sure enough ribbons not fully snapped in place. Picture is fine and I seem to have good control with short flight around the house. Do the camera rotate side to side also or just from straight pivoting down to ground . In other words if drone was facing me can the camera be moved to left or right without turning drone.
TanyaA
