I was in Northern Italy Alps for 3 days and took this lovely footage but its juddery ! Can anyone help me ? It was shot on 4k 30 fps with no filters ( ordered but not arrived in time ! Weather was hazy sun and extreme card
My Drone is doing the same thing. Do we need another DJI update?
@Pacefast what was the temperature at the time of the flight ,that looks very much like jello either because of prop imbalance, or the rubber mounts of the gimbal being very cold, and not acting as shock absorbers during flight
Editor ( Filmora )Is this a edit or is it the raw video directly from the SD card?
Auto mode , Normal , No ND filters and 4K 30 FPS ! Question can I improve itWhat settings? Auto or Pro mode.. Frame rate and shutter speed etc.
Might get rid of it with FCPX or Davinci Resolve anti flicker.. But will be challenging I think
So if this is an edited clip... did you set the timeline to the same FPS as the original video (30FPS)? And did you use the tele lens when you took the video?Editor ( Filmora )
The frame rate it was shot at is irrelevant as long as the capture frame rate matches the timeline frame rate.If I'm not mistaken, the UK is a PAL 25 or 50 fps country. If you were working on a 50p or 25p timeline you would loose 5 frames every second using a 30p clip i.e. to fit the frame onto a 25 frame timeline, the 30 frames must be reduced to 25, so 5 frames are deleted.
Have you tried shooting at 25 frames to see if the problem is still there (remember most movies are at 24 fps so are very similar to the 25 fps)
