Problem with calibration Gimbal
  • With the drone switched off twiddle the gimbal in all rotations and check that it is all free to rotate. from stop to stop.
  • If all is not well try blowing compressed air through the gimbal joints.
I use a double action hand pump with a jet nozzle (a big hand air bed pump)​
Try to calibrate again.
Does it go through the full dance on drone start up?
If the above does not work you might like to try the DJI tools software.​
Try this process. DJI Tools JointCourse and LinearHall.
Install Python and install DJI tools this process
I missed an important step.
After installing python you then need to use python to install pyserial.
DJ1 Mavic 2 Pro/Zoom GIMBAL CALIBRATION
Tools .
1. Download Python
2. pyserial
3. GitHub - o-gs/dji-firmware-tools: Tools for handling firmwares of DJI products, with focus on quadcopters.
GUIDE :
1. Download all tools
2. Install python
3. extract pyserial and dji tools to C:\DJI\
4. Open "command prompt" as administrator (cmd)
cd C:\DJI\dji-firmware-tools-master​
5. Install pyserial using pylon script
C:\DJI\dji-firmware-tools-master\python setup.py install
Turn ON Mavic 2 Pro/Zoom
Gimal Calibration
python comm_og_service_too1.py com3 WM240 GimbalCalib Jointcoarse
python comm_og_service_too1.py com3 WM240 GimbalCalib LinearHall
The following are instructions for a Mavic 2 Pro on com port 3.
The pause commands are not necessary its just so you can see what happens.(hit enter to proceed)
c:​
cd..​
cd c:\DJI​
CD C:\DJI\dji-firmware-tools-master​
pause​
pause​
py comm_og_service_tool.py com3 WM240 GimbalCalib JointCoarse​
pause​
pause​
py comm_og_service_tool.py com3 WM240 GimbalCalib LinearHall​
pause​
pause​
exit​
c:​
cd..​
cd c:\DJI​
pause​
pause​
pause​
pause​
pause​
pause​
exit​
Yes there is no problem with the rotation. Makes all movements freely. Yes my friend does he spend the whole dance in a drone start up. Is this process Python you say reliable? Thank you
Python is a programming language.
The DJI tools program on GitHub is written in the Python language.
This might be of interest.
Having just run a Gimbal calibration using the Go4App I noticed that at exactly 20% the roll motor is calibrated.
That is the motor that rotates the pitch arms, the motor at the back behind the camera.
What should I do? With the process I did it brings me to a point with the red arrows.
Giorgos
I am unable to replicate your error message.
The command you have entered
(py comm_og_service_tool.py com5 WM240 GimbalCalib JointCoarse)
is correct for a 'Mavic 2 Pro' or 'Mavic 2 Zoom' connected via com5.​
Your error message is saying that it does not recognise the given input 'COM5'.​
However you entered 'com5' not 'COM5'.​
I have tried using a wrong port number but do not get your error message.​
I have tried with the drone switched off and do not get your error message.​
I have not tried disconnecting the camera and then sending the command.​
There is an alternate code for the 'Mavic 2 Pro'
This command should also work.
C:\DJI\dji-firmware-tools-master>py comm_og_service_tool.py com5 M2P GimbalCalib JointCoarse​
The error message you are given seems to indicate that there is something wrong with the connection.
Are you sure the drone when switched on is on com5 ?
Giorgos
The command you have entered​
(py comm_og_service_tool.py com5 WM240 GimbalCalib JointCoarse)​
My friend I will try again COM5. This is my door. Maybe that's the mistake or I will put the command:
I tried them but again nothing ... I can not understand why? Is there another video better to watch? Is there another way?
My friend, I'm very happy because I did it and I calibrated with him
the driver. Everything is fine now and the automatic calibration is done without any problems. Thank you very much for the help.
Reactions: Fizzbang
I was just about to paste a link to that video.
Did you discover what was wrong with your first attempt?
Was it the wrong com port or another issue?
I am glad that you got it to work.
I just put the version Python 3.9.6 which said the commands. And it worked normally with great pleasure. I was putting the latest version and maybe it was not right with the commands. Below I write the correct ones with my door:
py comm_og_service_tool.py WM240 --port COM5 GimbalCalib JointCoarse
py comm_og_service_tool.py WM240 --port COM5 GimbalCalib LinearHall
Good Good Good
Reactions: Giorgos66
4Gabe
