problemas con el gps de mi mavic pro
Luis Amparo
REPÚBLICA DOMINICANA
hola amigos luego de saludarlo____nesecito su ajuda si alguien puede decirme cual es la diferencia entre los modulos de gps del mavic pro y el mavic platinum.
Translation: hello friends after greeting you____nesecito your help if someone can tell me what is the difference between the gps modules of the mavic pro and the mavic platinum.
Please post only in English. It is the posted official language of the forum. Google Translate can help you.
Reactions: Luis Amparo
The only difference between the Mavic Pro and the Mavic Pro Platinum is:
1 - The MPP has improved ESCs (Electronic Speed Controls) and quieter propellers. This results in slightly longer flight times.
2 - Color of the drone (MP is gray, MPP is "sleek silver")
The batteries are identical (other than the color) and can be swapped, if you have each drone.
flydeep
