Prop Bandolier Setup
CChoiVA
Virginia, United States
Thought I'd share a way of holding spare props in my hard case instead of having them bunched up in one spot. Bought a box of sew on and adhesive backed velcro off Amazon and cut them to size to fit my particular case. Cut the adhesive/rough side into 1in. sqaures and then the non-adhesive/soft side into one long strip. Just be careful if you decide to do this with your particular case and make sure there is enough clearance between the props and the main compartment so that it's not squeezing down on them once the lid is closed and causing the props to bend or warp over time.
Hangar Drones
