Propeller Motor Fraying?
solstevo
Yorkshire
Hi All,
Recently went to take off and like an idiot got my drone stuck on washing line, somehow it got under the propeller and started spinning around it, changed the blades, however the actual plastic that the propeller inserts into has frayed a bit obviously from the washing line, is this a big issue and how could i remedy this?
Thanks,
Solomon
Can you share some detailed photos so we can see what you're describing?
@solstevo on the Air 3, the props are actually attached through slots in the motor housing, and the part that actually locks them in place ,is underneath the top of the motor, what you can probably see as what you describe as fraying sounds like some of the debris from the line it caught on ,try carefully removing it with a fine pair of tweezers but be very careful not to damage the windings
Reactions: Cafguy
KiKiHUN
