Came across some warning signs that might help others re timely replacement of MA propellors. After getting an engine speed warning that caused MA to falter in air i found the rear engine mount to be exceedingly hot. I'd also noticed recently an increase in engine noise as well as the MA nose diving slightly on takeoff. Since installing a new set of propellors all symptoms have disappeared i.e. no speed warnings, smoother takeoff and quieter engine noise. It appears my MA props needed replacing. I've done probably about 100 + flights over a 12 month period. Litchy76.
