Questions - Huawei P20 Pro - System Navigation - automatically change?
Magmanthe
Norway
Hi Operators,
So for the ones here that has an P20 Pro, you are aware that the phone has different settings for the System Menu.
I use "Off-Screen Navigation key" for my phone (see pic for visualization)
However, this is not optimal for flying, as the Mavic-controller "clamps" cover the button at the bottom of the phone when inserting it.
Meaning I cannot use the back-function, "Pull-up-open-apps-menu", etc.
My workaround for this was to setup a Private-Spaces on the phone, with basically DJI Go 4 app installed, and the System Navigation menu set to "Three Navigation key".
This way, I get the software-keys on the screen, and those are not covered up by the Mavic-controller clamps.
This setup works fairly okay, but it is still a hassle and annoyance having to log into a separate part of the phone when flying..
Of course I could just change it in the menu manually, but I'm looking for "quality of life"-solution here, if possibel :)
So, pilots with the p20 pro, what is your setup like?
Android enthusiast; Is there an app for, or possible to easily create a way to automatically change which Navigation Menu style you use, based on the launch of an application? Or perhaps some kind of toggle-button that you can place on the screen that switches between the tho modes?
Any other thought on this annoyance regardring P20 Pro / Navigation Menu?
// Magmanthe
Starfixer
