Quick question. Im replacing the mainboard (firmware) SD card. What is the Format?
MavicFT1P
I think it is is Fat32. Not exFaT.
What is the best way to format it. Can i use mavic as a Drive to format it and then delete the folders?
it's a 16gb lexar, came with the mavic. I'm formatting it fat32, 4096 allocation size on PC.
Is this correct? Also I need a Volume Label.
16 views. It's a simple bloody question
A little help..
You can format in the Mavic.
If you use your PC simply fast format in exFAT & name it what you want.
You may get more help if you don't post things like “16 views. It's a simple bloody question “ Could be people don't know the answer.
Thx Cyborg.
Yeh i was trying to do stuff in a rush/sherty mood.
You are talking about the internal SD card that’s not removable right? Not the one that you usually write photos and videos to correct? That’s what I took your “motherboard (firmware)” to mean. Are you sure a 16 GB will work for that? I thought it had to be a 4 or 8 GB card. I assume it’s Fat32 but I don’t really know.
Thanks for the reply Brett.
The old ones came with 4gb cards glued in, but you know this.
It wont recognize the extra card space of a 16gb. Well, it might, dunno
point is it doesnt need to.
*Fat32 (4096) format done with Windows Format worked for me
Reactions: brett8883
Fordmanwon
